Clock & Mileage LCD Fade out and In
Hi Guys,
I have a 1996 Polo 1.4 L
My clock and mileage LCD ( on the dashboard ) faded out recently during a long days driving. It disappeared for a week or so but came back. However it's faded out again and obviously I need to fix it....
Many thanks
Sent from my Nexus 7 using Tapatalk
Many thanks
Re: Clock & Mileage LCD Fade out and In
You’ll probably need a new set of clocks, or have yours repaired with a new LCD
Crikey, that'll cost a bit.
Will it have to be reprogrammed for the mileage?
You can get a used set. As yours is early it might be before the immobiliser was standard too which makes it even easier
The clocks can be reprogrammed to match on mileage or you just record it had a clock change so it matches up on MOT etc.
Where are you based?
Hi, I'm in Stafford, in the Midlands. I'm sure it's an early model. Is there a way to check ?
Shame you are so far as I could’ve done it for you!
Pop up a photo of the clocks you have now. I’ll help you find a set
Cheers Alex,alexperkins wrote:Shame you are so far as I could’ve done it for you!
Here's a photo, engine was running when I took the photo, everything else works ok.
Kind regards
Yeah thats early clocks
Next question - what kind of key do you have?
Is it cut like this
or like this
Is it cut like this
or like this
Hi Alex, it's the second one...alexperkins wrote:Yeah thats early clocks
Is it cut like this
or like this
Kind regards
Ok then, im pretty sure theres no immobiliser on that key. Can you PM me your reg as final question so I can just check clock part numbers?
Sure Alex,alexperkins wrote:Ok then, im pretty sure theres no immobiliser on that key. Can you PM me your reg as final question so I can just check clock part numbers?
It's P215 LVT
Kind regards
Ok, part number should be 6N0 919 910 L
Theres a few on ebay - this one is a decent price
https://www.ebay.co.uk/itm/Vw-Polo-6N1- ... Sw71xZmBrR
It should be a drop in replacement without the need for coding unless you want the mileage corrected
Cheers Alex, that's brilliantalexperkins wrote:Ok, part number should be 6N0 919 910 L
Many Thanks
