Going to look at a mk2 on the weekend.
From 89, with service history & looks solid from the pictures but I was wondering what are the key points to look for?
The carb needs a little work & some body work visible but interior looks sweet & so does the engine bay.
Mk2 Buying Guide
Re: Mk2 Buying Guide
Main things are that it idles and warms up properly
They suffer awfully from rust so have a really really good lol underneath
The petrol tank is also made of steel and the filler neck dots out so be sure to have a good look at that
Cambelt and waterpump should be done every 5yrs or 60k and a service every year.
Any particular areas to keep a look out for in term of rust. From what I've been told the car I'm looking at has been stored well during it's life so there isn't too much rust on it.alexperkins wrote: Tue Dec 19, 2017 8:31 am Main things are that it idles and warms up properly
I will check out the fuel tank, I believe it has been serviced regularly so will check out the service history.
Generally the floor pan, jacking points, where the rear exhaust mounts onto are the main places
So I did an MOT history check, it was SORN from 2012-2017 & no mention of corrosion in MOT history, which can only be a positive
The first MOT 2017 was a lot of brake hoses & fuel lines were corroded but appears to be fixed.
What is: "Offside Front Macpherson strut has slight movement at the upper attachment"
Only on 50k miles. Not sure if thats a good thing or a bad thing
That means the top mount is possible a little worn on that side
Low mileage is beneficial in some ways, and not so great in other. Time eats parts regardless of mileage
Be prepared to replace bushes etc as time goes along S rubber will perish after 28 years
It sounds like it could be a good little car
Nothing too serious then.
Aware it'll need some work & desperate to get to work on it as it'll give me the chance to work on an older car.
Unfortunately will have to store it for a few months while I get a house with a garage, any car covers you could recommend as it might be outside for a period of time
