High level brake light
Posted: Sat Jan 06, 2018 11:38 am
Wife has a 1.4 Polo 11 plate
The two rear brake lights work but the high level one has stopped
Thinking I would change a bulb took the red lens cover off and there are no bulbs to be changed
The unit is a circuit board with several small leds soldered to it
Took said circuit to a tv repair shop to have it tested and ALL the bulbs light up individually and as one strip
Power is also at the plug that's popping out into the roof spoiler/high level light feed
Question ...... is there a separate fuse for the High level light?
Anyone else had this problem?
