Car has 70000 miles on it and only recently has been making a chiming/whistling noise not only when accelerating but also once I have turned the car off. After I turn the car off it takes about 3 seconds for then a long whistling noise to happen. It sounds like it is coming from the top of the engine, near the coolant pump where all the piping is on the left hand side of the engine. Engine code is BMD, 1.2 litre SOHC petrol.
Has anyone ever experienced the similar problem and if so what is the problem and how can I fix it? If anyone else knows what it may be all advice and help is appreciated. Thanks.
Whistling/chiming noise coming from engine area when driving/accelerating
lrobinson333
- Drives: mk4 Polo 2006
