BCM High to BCM Max, AFS, LED Headlights and HBA
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
Hi, I have a VW Polo 6R with 6R0937087K BCM and I bought a 7E0937090C BCM. Which wires I have to change in my Polo after the new IC CAN line?
Lights switch connector:
http://www.imagebam.com/image/9ed372710073663
http://www.imagebam.com/image/8299a0710073693
http://www.imagebam.com/image/79a65d710073733
Relays:
http://www.imagebam.com/image/f23c67710073753
Dimmer connector:
http://www.imagebam.com/image/2e8390710073803
http://www.imagebam.com/image/0f03d3710073823
Switch:
http://www.imagebam.com/image/c2ef2a710073883
AFS:
I plugged the AFS module without LED headlights and AFS sensor. But I receive an error about "Address 19: CAN Gateway":
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0251
   Revision: BF046001
   Coding: 002200
   Shop #: WSC 12469 483 00190
   VCID: F0EB54F39863
1 Fault Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 82348 km
                    Time Indication: 0
                    Date: 2010.14.27
                    Time: 09:55:27
Address 55: Xenon Range (J431)       Labels: None
   Revision: --------    Serial number: --------------
   Coding: 0202000001000000
   Shop #: WSC 02757 790 50316
   VCID: F7F96FEFFD0D
4 Faults Found:
5256213 - Front Left Ride-Height Sensor
          C1034 15 [137] - Open or Short to Plus
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
5256725 - Rear Left Ride-Height Sensor
          C1036 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
5277205 - Positioning Motor for Headlight Range Right
          C1086 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
The errors about "Address 55: Xenon Range" are normal because LED headlights and AFS sensor are not plugged yet.
P.S. Where can I buy a pin remove tool from Europe?
Last edited by federicodrdpro on Fri Jan 19, 2018 7:13 pm, edited 1 time in total.
Re: BCM High to BCM Max, AFS and LED Headlights
Hi Federico, this is the installation guide (approximate) that you must follow to adapt the original wiring to your new BCM.
https://drive.google.com/file/d/0B2nv91 ... NXS1U/view
A fuse box image is necessary too.
A complete and recent AutoScan is necessary.
https://www.ebay.co.uk/sch/i.html?_from ... ol&_sop=15
federicodrdpro
Thanks ciclo! Now I study the installation guide.
This is my fuse box: http://www.imagebam.com/image/a803f8712448733
VCDS Version: Beta 11.2.0
Data version: 20110305
Tuesday,09,January,2018,13:03:43:10074
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 44 55
VIN: WVWZZZ6RZCY020628
55-Xenon Range -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H06 8410
   Revision: 11002001    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021 001010
   VCID: E5C535A757A1
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416F00B2842B14E482D900421700
   Shop #: WSC 00788 648 00255
   VCID: 87191F2F8DED
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326F1EFBD6EF
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0251
   Revision: BF046001    Serial number: 0434 160111826
   Coding: 3CB02BBF08E32600923808006D2F8CD00088672F60860000200000000000
   VCID: 458555277761
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB
   Component: J386__TSG_FT  008 1611
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD
   Component: J387__TSG_BT  008 1611
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 951 171 A    HW: K89 511 71A
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 08BC32
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NWXFQ
   Coding: 003232
   VCID: 4A9F661B5E7F
   Driver's Airbag Crash Sensor:
   Serial number: 3575HRB40550INGS999T
   Passenger Side Airbag Crash Sensor:
   Serial number: 3585HRB40570INGSBHPF
   Driver's Rear Airbag Crash Sensor:
   Serial number: 3515RRB40510JNPM7P50
   Passenger's Rear Airbag Crash Sensor:
   Serial number: 3525RRB404P0K4DOA8O1
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 3A7F36DB0E9F
   Revision: BF046001
   Coding: 002200
   VCID: F0EB54F39863
1 Fault Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 82348 km
                    Time Indication: 0
                    Date: 2010.14.27
                    Time: 10:04:14
   Component: IMMO          H03 0505
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
   VCID: EADF469BBEBF
Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
   Part No: 6R0 423 156 B
   Coding: 11210
   Shop #: WSC 00788
   VCID: 2F69178FC5DD
   VCID: F7F96FEFFD0D
4 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 10:04:38
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 10:04:38
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 10:04:38
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 10:04:38
End   ---------------------------------------------------------------------
federicodrdpro
I studied the Installation guide :lol: , but there isn't an electric scheme and I seen different versions of wirings (benji58, benzinkopf..)
If I see the benji58 version.
I already have T41/9 to SB10
SB4 is free, SB5 is for RVC camera and already have SB57(can I use SB60 like benzinkopf..? it is free) and why output to SB49 (fuel pump relay)? :?
New IC CAN line is not a problem.
I don't understand the wires in fusebox. (SB59, SB57, SB39)
T73b/11, T73b/68 input from pin?
T73b/2 output to?
In benzinkopf wiring I see also T73b/1. There isn't in benji58 wiring. Same for T73a/1.
connection of T73b/43, T73b/7, T73b/29?
T73b/4 to dimmer
connection of T73a/6 and T73a/45?
T41/38, T41/39, T41/40, T41/41 (HBA?)
I have read from a iichel post:
Step 4:
Remove the OBD connector from its holder and remove and isolate T16/6 and T16/14 (orange/black and orange brown)
Run a new twisted pair of wires. One goes from T73b/22 to T16/14 and the other goes from T73b/23 to T16/6.
This is your new CAN Diagnostics network.
Step 5:
Remove steering wheel and indicator stalk unit.
Remove the T41/3 (orange/black), make a Y connection and make a connection of the wire to T41/3 and T73b/19.
Remove the T41/2 (orange/brown), make a Y connection and make a connection of the wire and make a connection to T41/2 and T73b/18.
This is the new CAN powertrain network.
I can't see this step on the installation guide.
I think to install OEM RLS and HBA next. I can prepare the wirings for their.
P.S. I have to buy a new VCDS cable. Which one know OBDeleven?
As I said: (approximate)
What a mess you have mounted in your previous post!
Forget completely what you have read about iichel's post, it is not related to your 6R non Bluemotion.
There are different versions of the wiring looms to do depending on:
- The 6R model. Many versions.
- The equipments you want to add to your 6R. Many possibilities.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
federicodrdpro wrote: Tue Jan 09, 2018 10:38 am
   VCID: F7F96FEFFD0D
4 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
I suppose you had installed the AFS control unit for T5. And it has parametrization for two suspention height sensors (front and rear) the right parametrization for Polo works only with one rear sensor. So you need find the AFS control unit for Polo 6R or reprogram current control unit. You will have to find parametrization file and interface(cable) which able to provide this (VagCanPro or ODIS).
firegrafik wrote: Thu Jan 11, 2018 5:34 pm
   VCID: F7F96FEFFD0D
4 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 82348 km
                    Date: 2074.14.27
                    Time: 09:55:51
The unit is correct but badly coded ... for VW Transporter/Multivan.
federicodrdpro
ciclo wrote: Wed Jan 10, 2018 12:11 am What a mess you have mounted in your previous post!
Yes, I know. :lol:
Halogen to LED headlights wiring:
Which fuses I have to use?
Remove J331 -> RELAY carrier
IC CAN:
T73b/54 -> T32/28
T73b/57 -> T32/29
And prepare 2 wires for HBA
STALK:
T41\9 -> SB10 (+15)
BCM:
T73b/2 -> ?
T73b/4 -> T6/3 (new dimmer) (isolate original T6/3)
T73b/7 -> T17/16 (wire)
T73b/11 -> SB60
T73b/12 -> T6/5 (right tail lights) (then to RVC and Dimming Mirror)
T73b/29 -> T10/2 (red connector)
T73b/43 -> T10/4 (red connector)
T73b/68 -> ?
T73a/2 -> ?
T73a/6 -> T17/17 (wire)
T73a/45 -> T10/3(red connector) (isolate original T73a/45)
T73a/62 -> SB34
T73a/63 -> ?
HBA:
BCM:
T73a/1 -> SB36 (Why new wiring to right headlight?)
T73a/37 -> T10/2 (Auto Switch connector)
T73a/62 -> T41/40
T73b/1 -> SB34
T73b/4 -> T10/10 (red connector) -> T6/3 (dimmer) and PIN1 RELAY Ambient Light
T73b/8 -> T41/39
T17/2 -> T10/1 (red connector) -> PIN3 RELAY FOG
* T10/2 (red connector) -> T10/9 (Auto switch connector) (isolate original T17/3)
T17/8 -> T10/3 (red connector) -> PIN5 RELAY FOG
T17/9 -> T10/4 (red connector) -> T10/7 (Auto switch connector)
T17/10 -> T10/5 (red connector) -> T10/6 (Auto switch connector) and PIN2 RELAY FOG
T17/11 -> T10/6 (red connector) -> T10/1 (Auto switch connector)
T17/15 -> T10/7 (red connector) -> T41/38 -> SB(4?)
T17/16 ->T10/8 (red connector) -> T10/3 (Auto switch connector)
T17/17 -> T10/9 (red connector) -> T10/10
T10/4 (Auto switch connector) -> T41/41 and SB15
T10/5 (Auto switch connector) -> PIN5 RELAY FOG
Ambient light RELAY:
PIN2 ->PIN2 RELAY FOG
PIN3 -> T10/7 (red connector)
PIN5 -> SB1 (5A)
Anti dazzle mirror:
T8/1 -> SB25
T8/2 -> GND
T8/3 -> NEW CAN H
T8/6 -> MQS on roof light
T8/8 -> NEW CAN L
RLS:
Rain sensor:
T3/1 -> SB23 (+30)
T3/2 -> GND
T3/3 (Bus Lin) -> T73b/24
Mirror:
T6/1 -> SB25
T6/2 -> GND
T6/3 -> T73b/12 ?
firegrafik wrote: Thu Jan 11, 2018 5:34 pm ..
ciclo wrote: Thu Jan 11, 2018 6:23 pm ..
Ok, I didn't know that was necessary buy a VW Polo module. I am waiting to receive the VagCanPro cable, I will edit the parametrization file. But I never used VagCanPro cable. :mrgreen:
P.S. Ciclo, can you check my wirings? :D
Last edited by federicodrdpro on Thu Jan 11, 2018 10:12 pm, edited 2 times in total.
firegrafik
Hope so, but I read some post of the Polo 6R hatch owner, he faced with such issue, and there is not only by coding in the AFS control unit is configured but also parametrisation (like RDKS unit) so it is high possibility even it will be correct coding the fault concerning front height sensor will not go. And also it could makes wrong headlight range angle depending on rear axle height, because of the wrong wheel base
For example same thing is with PDC control unit, the sensors quantity is set: only by paramtrization: 3 rear (some Skoda models), 4 rear, 8 (front+rear)
federicodrdpro
I can't edit the AFS module coding with VAG cable. I receive an error "Coding rejected Error 31: Request out of range".
firegrafik wrote: Thu Jan 11, 2018 6:44 pm
Ok ... to get rid of doubts, he can try this coding:
0110000001000000
and tell us what happen.
firegrafik
federicodrdpro wrote: Thu Jan 11, 2018 6:48 pm I can't edit the AFS module coding with VAG cable. I receive an error "Coding rejected Error 31: Request out of range".
I suppose it is becase that AFS control unit has EEPROM set (parametrization) for T5, so it rejects any other coding.
firegrafik wrote: Thu Jan 11, 2018 6:58 pm
Maybe it's because he is using one of rather antiquated VCDS version.
That version is already a relic. :lol:
federicodrdpro
firegrafik wrote: Thu Jan 11, 2018 6:58 pm ..
ciclo wrote: Thu Jan 11, 2018 7:03 pm ..
Maybe it's because you're using one of rather antiquated VCDS version.
Yes, I know. I think, I will receive a new VAG cable 17.8 version tomorrow. I update you soon :lol:
Today is arrived the new 7E0937090C BCM :twisted:
OK ... make a new autoscan with your new VCDS version and my coding for address 55.
You have to tell me all the new equipments you want to install in your 6R to tell you which wires you have to modify, add, isolate, etc ...
Depending on what you say you will spend a certain amount of money,...in case, for example, you say that you are absolutely sure that you want to install HBA you will spend a large amount of money in realizing your project.
