Error code
DKPOLOGT
Drives: Blue GT
Error code
Post by DKPOLOGT »
Can anyone help with translation of the following code.
Component : bcm pq26 hi4r
Code : 227080
I cant seem to google the code.
Cheers :)
Re: Error code
what device did you use? vcds?
if so, maybe a full autoscan would be more useful
DKPOLOGT
Drives: Blue GT
Re: Error code
Post by DKPOLOGT »
iichel wrote:what device did you use? vcds?
Hello :)
I used carista.
This is the print.
Re: Error code
227080 - Turn Signal Switch
Further explanation not possible... could be Signal implausible, electrical malfunction, short to GND, short to plus... needs better tool...
DKPOLOGT
Drives: Blue GT
Re: Error code
Post by DKPOLOGT »
iichel wrote:227080 - Turn Signal Switch
Thanks man.
Turn signal functions 100%.
I have deleted the code. Ill have a check back in a few days for a new scan.
Btw. Where do you look up the code ?
Re: Error code
Re: Error code
DKPOLOGT, I think that you will find that Carista is a bit slow to catch up with some of the newer cars newer fault codes, but they will get there with some more time. I've found that on a couple of occasions, but I had VCDS to tell me watch the correct code was.
One thing though, as far as I've found, Carista will faithfully report all faults, it is just that it can not give any or correct descriptions to some of these newer codes, older codes, ie codes numbers that VW Group has assigned to cars in the past 10 years will always get correct descriptions given to them by Carista.
