Flashing 3rd brake light.
Carl0s
Drives: 2001 1.4 Automatic
Post by Carl0s »
Hello, I share a mint 2001 1.4 auto with my sister. 71,000 miles & we’ve owned the car for nearly 14 yrs. It sailed through its mot yesterday (always does) Just had a call from my sister saying the led strip above the rear screen flashes whenever she brakes. A work colleague was following her & told her. It’s never done it before. Any ideas?
No parts were needed for mot & it was ok before it. The other day she accidentally left the handbrake on the first notch & got a beeping noise. Has this anything to do with the flashing light?
Cheers for any help
Carl
Re: Flashing 3rd brake light.
The beeping is normal - its to remind you the hand brake is on when you are moving
As for the flashing light, it sounds like the LED cluster has failed. Its not repairable, so will need to be replaced. Theres two grommets on the inside of the bootlid which release two catches so it can be withdrawn from the bootlid
Carl0s
Post by Carl0s »
Yep totally failed now. How much are they to replace.
I’ll take it to a garage as spanner’s electrics & me don’t mix lol
Sadly, no longer available from the dealer
The part number is 6N0 945 097D
I found this one on ebay which will work
https://www.ebay.co.uk/itm/VOLKSWAGEN-P ... Swf~9ZaLgS
