2009 Polo Match 60 - Faulty cigarette lighter - Fuse issue ?
stvn66
Drives: 2009 Polo Match 60
Post by stvn66 »
This is the second time my daughters cigarette lighter has stopped working and she needs it for her Sat Nav.
I looked at the manual and the fuse layout is slightly different?
I checked the fuse circled in the image which looked fine, does anyone know if I have checked the correct one?
Thank you.
Re: 2009 Polo Match 60 - Faulty cigarette lighter - Fuse issue ?
Looks like you're slightly in the wrong section; this looks like a Polo 9N3.
But, doesn't matter, a Polo is a Polo and for this one, the cigarette lighter fuse is fuse number 49
You'll find it on the row on the right of the circled fuse, 6th from the bottom. It now has a 10A fuse. Should be 15A according to the wiring diagrams.
stvn66
Post by stvn66 »
This is the correct solution to my problem.
The circled 15amp fuse is incorrect and should have been a 20amp fuse.
I checked the red 10amp as per previous comment and it was fine.
I checked the blue circled 15amp and it was blown and when replaced the cigarette lighter socket worked :)
** Would have been nice if the manual viewed the same as the actual panel above, it needs flippings horizontally ?? **
I totally agree with you...
RHD
Image :lol:
Thank you very much for sharing your experience. :wink:
stvn66
Post by stvn66 »
RHD....!
That never occurred to me. Now it makes sense :?
