2012 headlights not working
VWbrian74
Drives: 2012 match tdi
Post by VWbrian74 »
The head/ dipped beam lights on my 2012 tdi Match are not working either as DRLs or on the light switch but they do flash using the indicator stalk as usual, local dealer suggests full diagnostic needed, anybody had same problem or got a suggestion.
Re: 2012 headlights not working
Hi VWbrian74, welcome.
Take two pictures (both sides) of the wires that reach the light switch connector to be able to indicate you a suggestion.
- Remove the light switch from the dashboard.
- Take the pics.
Have you made any changes to the lights of your 6R?
