Also, when i apply the brake, theirs little screeching then aswell!!
Is it my brake pads? Or the discs?
It's only recently come back from service, i'm pretty shocked that it's even making the noises it is!
all advice appreciated! thnx in advance!
DITTO!!!polopowah wrote:mine does exactly the same, when going round small roundabouts at half lock if i have window open you can hear a high-pitched squeel and sometimes when i apply the brake
any ideas??![]()
-Ben-
Mine has discs all round!zahir_213 wrote:mine used to do this, the bit around the brake drum was catching the drum at the back, not sure if ive explained this properly. My dad fixed it by bending out the bit around the drum and then it was fine
alright mate the noise u on about is from your brakes its due to dust build up causing the brakes to bind (stick) it requires stripping and cleaningkapur wrote:Mine has discs all round!
I doubt it's the brakes! It could be, not ruling it out!
Just that it made the noise at low speed round a bend, EXACTLY the same as polopowah!!!
without applying the brake and letting it roll at about 10/15mph it makes the noise!
Can only hear it from the left hand side, while going round a bend towards the right!
I cant remember hearing it from the drivers side of the car!
