Hi after some help.
2014 Polo Match1.4.
Launch Tec Fault Code B101913 Crash sensor for side airbag ,rear, front Passenger side -OPEN CIRCUIT. Where do I start
Any suggestion would be most helpful bit of a novice to say the least!!!
Crash Sensor Open circuit
bedrockskyblue1
- Drives: 2014 Polo 1.4 Match
Re: Crash Sensor Open circuit
To a novice:
crash sensor is airbag system is go to a garage.
To an expert:
Clear DTC and see if it returns.
If so, get wiring diagram and verify wiring or replace crash sensor.
To an expert:
bedrockskyblue1
Carried out some checks obd code 1910 passenger deploy loop short to voltage.
Any one else experienced similar fault.
It all came about after heavy storms last week, however that just may be a coincidence.
Could be corrosion in the door connector.
bedrockskyblue1
Thanks for the pointer, will carry out further investigations.
Will update in next few days.
niallrfocus
- Drives: 1.2 tdi 6r
Hi did you get this fixed I've got the same fault code, 2014 polo.
niallrfocus
niallrfocus
