5 door interior in a 3 door
Bazzad88
Drives: 6n2 polo GTi
Post by Bazzad88 »
Hi does anyone know if the 5 door front seats have the hole in the side of the bolster for a reclining mechanism to be fitted and if so are they a pig to do? Thanks
Re: 5 door interior in a 3 door
The frames are the same. Just needs a cut and the mechanism fitting internally
Bazzad88
Post by Bazzad88 »
Ok cool, any idea how hard it is to do?
Youll need to remove the backrest on both seats (old and new) strip the fabric off, swap it all over
Its a few hours work
Bazzad88
Post by Bazzad88 »
Ok thanks mate, soz about all the questions haha, is the fabric stitched all the way around or does it come undone somewhere?
It is clipped in at the bottom. you have to remove the backrest, then you can release the tabs and the tension on the fabric and it comes up and off, the backing pad will stay attached though as this has wires on it. This isnt a job for the feint hearted and its important to get the fabric back on correctly or itll look s**t
