Where is the gearbox foller plug?
Northstar
Drives: Mk4
Post by Northstar »
Ive googled images and diagrams but can't find the flipping thing!
Is ig on the front of the gearbox? Tried using a mirror too but no luck
Re: Where is the gearbox foller plug?
Depends on the gearbox. Some of them are above the driveshafts at the back of the gearbox
What engine/gearbox have you got? The codes will be on the label underneath the boot carpet (for example engine codes start A or B and are three letters like BYD, and gearboxes are generally Dxx on wards like DXB, ETG, FHB etc)
Northstar
Drives: Mk4
Post by Northstar »
Hi alex,
Engine code BBM then JHN
Northstar
Drives: Mk4
Post by Northstar »
Forgot to say its manual if not indicated i the code
Northstar
Drives: Mk4
Post by Northstar »
I have found a plug on the back, but it could be the flywheel inspection one
