nothing on key turn, fuse blown?
Garyrob
Drives: 6n2 1.4tdi colour concept
Post by Garyrob »
Thw window switch stopped working so I took it out to have a look at it and give it a clean. Think i've managed to blow a fuse somewhere as now there is no power at all. When you turn the key nothing happens.
I thought there would be a main fuse somewhere but cant see one. Not sure what fuse blew, need some help.
Garyrob
Re: nothing on key turn, fuse blown?
Post by Garyrob »
Don't think I phrased that the best, I still have lights and the battery has power,
Update: I'm an idiot, after another 10 mins trying check little fuses that are awkward to get out. I realised that my alarm was still on, explains why the ignition was doing nothing. Anyway that problem solved. window switch still not working though:(
Glad you got it working
Window wise, its likely broken wires between the door and the body as this is very very common now. Pull the rubber boot back and check the wiring for splits and breaks
