nothing on key turn, fuse blown?
Posted: Sat Sep 01, 2018 1:23 pm
by Garyrob
Thw window switch stopped working so I took it out to have a look at it and give it a clean. Think i've managed to blow a fuse somewhere as now there is no power at all. When you turn the key nothing happens.
I thought there would be a main fuse somewhere but cant see one. Not sure what fuse blew, need some help.
Re: nothing on key turn, fuse blown?
Posted: Sat Sep 01, 2018 1:31 pm
by Garyrob
Don't think I phrased that the best, I still have lights and the battery has power,
Update: I'm an idiot, after another 10 mins trying check little fuses that are awkward to get out. I realised that my alarm was still on, explains why the ignition was doing nothing. Anyway that problem solved. window switch still not working though:(
Posted: Mon Sep 03, 2018 4:55 pm
by alexperkins
Glad you got it working
Window wise, its likely broken wires between the door and the body as this is very very common now. Pull the rubber boot back and check the wiring for splits and breaks
