bcm coding remote key stop working
Luigid
Drives: Polo 6r 1.6 tdi
Post by Luigid »
good evening, I tell you my misadventure these days, using a vcds cable of bad quality and reprogramming the bcm, always gave me coding accepted but the code did not change, suddenly shows a completely different code from my original (fortunately saved thanks previous scans), so the 4 electric glasses are not working, as well as the tailgate and the remote key, fortunately using version 17.8 the next day I managed to put the original code back and everything is working except the remote key, if I go on bcm (control unit n9) adaptation -> remote control adaptation click on "read" goes out in green N / A instead of "key", even restoring the settings on channel 00 remains, same thing for the 2nd key, what can I do? Thanks in advance.
ps: my car is a polo 2010 6r 1.6 tdi bcm model: BCM PQ25 H+4 H46 0207
Re: bcm coding remote key stop working
Throw away the current cable, get a proper one.
Remote control matching --> http://wiki.ross-tech.com/wiki/index.ph ... l_Clearing
Luigid
Post by Luigid »
thanks buddy, it worked perfectly for both keys, I have no idea how he made all these problems the old cable, thanks again.
Cheers mate, happy it worked.
