BCM Max4 H80 0733 7E0937090
CNK
Drives: 6R
Post by CNK »
BCM PQ25 Max4 H80 0733 7E0937090
7E0 937 090 Z4Y
Supports Automatic lights, Light Assist, Bixenon and "LED headlights" (LED DRL module and LED Headlight module). 6R, T6, etc...
Used in my 6R with Full LED headlights - all works great!
Price: 500 PLN / 116 EUR / 101 GBP / 133 USD / 8858 RUB
PayPal
pranaynewton
Drives: 6R 2014 (Vento TSI 1.2L)
Re: BCM Max4 H80 0733 7E0937090
Post by pranaynewton »
Is this still available? What's the supported key frequency? Is the full part number 7E0937090D?
CNK
Drives: 6R
Post by CNK »
no it's part without letter on the end of part number
pranaynewton
What is your key frequency? 434 MHz? I have attached an image of my key below if it helps. Do you think your BCM would be compatible with my key?
Yes this BCM operates at 434 MHz.
CNK
Drives: 6R
Post by CNK »
yep, I have 5K0 837 202 Q key which is also 434 MHz
pranaynewton
Great! Which LED part number did you use on your Polo?
CNK
Drives: 6R
Post by CNK »
pranaynewton wrote: Wed Feb 27, 2019 12:23 am Great! Which LED part number did you use on your Polo?
6C1941036 + 6C1941035 (LHD)
or
or 6C1941036A + 6C1941035A (LHD, GTI)
or
6C2941036 + 6C2941035 (RHD)
