Page 1 of 2
Cup Holders
Posted: Fri Aug 20, 2004 6:58 pm
by wul3er
Am i right in thinking that some polo's come with cup holders, similar to those on the mk4 Golf.
Does anyone have these, or seen them
Posted: Fri Aug 20, 2004 9:38 pm
by Redline
Indeed they do.
The S, SE, 16v and GTi models came with (as I recall) one cupholder that pops out of the console housing the stereo and central air vents.
E models were not fitted with the cupholder. Or anything else really!
More info here
http://www.geeforty.freeserve.co.uk/history/mk3f.htm
Posted: Sat Aug 21, 2004 12:42 am
by wul3er
I have the 1.4E can i buy these for my car and where would it go and how would it be fitted.
Posted: Sat Aug 21, 2004 11:35 am
by SpikeyG40
if you look under where your radio/cd player is, u should see a couple of screws or something, thats where they go, n i believe you can put them on the E model
Posted: Sat Aug 21, 2004 1:48 pm
by ICEYPOLO
wul3er wrote:I have the 1.4E can i buy these for my car and where would it go and how would it be fitted.
this could be what you're after.... or a solution at least!
click the link, check 'product over view', then 'Polo', then 'interior parts' and hey presto!
https://sslrelay.com/s74326199.oneandon ... shopscript
scott
Posted: Sat Aug 21, 2004 4:36 pm
by polopowah
i found some cup-holders on my 1.0E, as you open the glove-box, they are only very basic though, not quite the same as the ones in the 9n my dad has
-Ben-
Posted: Sun Aug 22, 2004 3:01 pm
by polo2k
on the mk5 the holders go on the upside down flat surface under the stereo and above the heater controls
vag parts can supply and i fitted them to the equivilent of a 1.4E
Posted: Sun Aug 22, 2004 4:14 pm
by wul3er
Cheers for the help. Im might get the ones from Vag parts, Its the exact ones i wanted so thats quite cool.
I already the 2 in the glove box as well, but the Mcd's cup fall over when turning and makes a right good mess.
cup holder and try
Posted: Sun Aug 22, 2004 4:54 pm
by jon_poloV
i have a cup holder that pops out under my stereo bit and a small tray thg!
to be honest i wouldnt ever use the cup holder in the car cos id go mad if netn spilt!
jon
Posted: Sun Aug 22, 2004 4:58 pm
by Si_GTi
wul3er wrote:I already the 2 in the glove box as well, but the Mcd's cup fall over when turning and makes a right good mess.
When I get a McD's brekkie I have the coffee - I put that in my cupholder, and when I got to the first roundabout it was slopping out all over my ashtray/gearlever gaiter
buggers fill it too full... or I drive too quickly! Holder's pretty solid though, the cup itself stayed put all the way. Just the damn coffee that wanted out
BTW, for those of you that don't already have a cupholder: is the coin tray there or do you just have a blank panel?
Posted: Sun Aug 22, 2004 11:48 pm
by wul3er
I dont have the cup holders (as you might have guessed, lol) I think i do have a coin holder, could that be this part.
Were the stereo is i have bigger version is in the spare din, Move that and put the cups here, This will also allow me to out my next trick in there.
Posted: Tue Aug 24, 2004 10:31 pm
by JWC
Redline wrote:Indeed they do.
More info here
I have the SE - misserable buggers not putting something that cheap in the other models. It must cost them about 20p
Re: cup holder and try
Posted: Tue Aug 24, 2004 11:35 pm
by wul3er
jon_poloV wrote:i have a cup holder that pops out under my stereo bit and a small tray thg!
jon
You wanna sell it
Posted: Wed Aug 25, 2004 1:15 am
by Redline
Have to remember that the E model was stripped out to save weight
Well, thats what I like to believe anyway!
Strangest thing about the specs on the Mk5 Polo is that even the E got electrically heated and adjustable side-mirrors, but only wind-up windows. Know which I'd prefer.
Posted: Wed Aug 25, 2004 8:23 am
by JWC
Yeah, with lower models, the stripping often doesn't make sense from an economic point of view.
I mean drums on the back. I fail to see the logic. Drums are not lighter, and they are not cheaper, why not make all your cars with the same hub? And with the electrically heated mirrors, I suppose its because its too costly to develop two versions, they probably outsource it anyway.
Look at the eurofighter... Its the same. The british don't want a cannon because its too costly 2m per year to maintain for a fleet. So they asked for it to be removed. Then they had to make a blank of equal size and weight. Then that had to be certified. 90m later, they decided probably best to put the real cannon in, but not use it, don't wire it up. -Sounds like VW!
