BlueGT Front Brake Disc
Posted: Fri Jan 25, 2019 3:11 pm
by MarkoPolo
Looking to replace the front discs and pads on my 6R BlueGT.
Does anyone know what size disc I need? There seems to be 3 options, 256mm, 288mm and 312mm.
I've recently changed the back pair to some Brembos and now that GSF have another 60% sale, I thought I'd treat the front too :P
Thanks,
Re: BlueGT Front Brake Disc
Posted: Fri Jan 25, 2019 3:38 pm
by RUM4MO
Well 256mm not possible, 288mm probably, 312mm normally only for GTI.
You really do need to check proper brake manufacturer's websites to find out which brakes your car has.
Posted: Sat Jan 26, 2019 10:52 pm
by iichel
Polo GT 140hp/150hp indeed takes 288mm discs a the front
Posted: Wed Feb 06, 2019 11:47 am
by MarkoPolo
iichel wrote: Sat Jan 26, 2019 10:52 pm Polo GT 140hp/150hp indeed takes 288mm discs a the front
Thank you!
Posted: Thu Feb 14, 2019 8:25 am
by Peter N
standard is 288mm
Posted: Tue Mar 12, 2019 3:02 pm
by Chloe1x2x3
Hi Marko
Did you have any issues with the 288mm front brake discs fitting? I’ve ordered myself some and the garage I took it to fit them said they were too small?
Thanks in advance
Posted: Fri Mar 15, 2019 8:41 pm
by DKPOLOGT
Go for mtec brakes.
Posted: Sat Mar 16, 2019 9:24 am
by RUM4MO
Chloe1x2x3 wrote: Tue Mar 12, 2019 3:02 pm Hi Marko
Thanks in advance
Did you get anywhere with this job? Where did you buy the 288mm diameter vented discs from?
Posted: Tue Mar 26, 2019 1:55 pm
by MarkoPolo
Thanks in advance
Haven't done this yet but have ordered some from GSF Car Parts.
Should arrive tomorrow and going to be fitting them on Saturday.
Will update you after(if) they are fitted
Sent from my ONEPLUS A5000 using Tapatalk
Posted: Sat Mar 30, 2019 9:37 pm
by MarkoPolo
288mm is the correct size for the Front on the BlueGT
Fitted mine today, looks mint
Part I ordered : https://www.gsfcarparts.com/601vg0101
