Anyone installed these headlights?
madalinanton
Drives: Polo BlueGT
Post by madalinanton »
Found them on Aliexpress, the seller reckons are plug and play for a car that came with halogen. Anyone on the forum purchased them?
Nashy
Drives: 1.2 Moda 5dr 2011
Re: Anyone installed these headlights?
Post by Nashy »
madalinanton wrote:Found them on Aliexpress, the seller reckons are plug and play for a car that came with halogen. Anyone on the forum purchased them?
I’ve been looking into these aswell would be good to know if there actually plug and play
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Yes. they are plug and play for Halogen H7 headlight polo with 10pins connector, but
1) its design for LHD car. so RHD buyers pls beware as you cant simply change the projector cutline.
2) the leds DRL is going to be connected to your small parking light and its not as bright as original bixenon model. and due to lower consumption, you are going to get error warning light for bulb.
3) since it got both the high beam shutter inside the projector, with this, you will get two highbeam lights, the one inside the projector as well as the side H7 light which is ‘cornering’ light in original setup.
madalinanton
Drives: Polo BlueGT
In the description, it actually says it's for right hand side...
benzinkopf
Ok. if the seller said so, then they already made the headlight for RHD models. back then, (3-4 years ago) its not an option.
