polo 6r upgrade
minib
Drives: polo 1.6l tdi 90 dsg 2010
polo 6r upgrade
Post by minib »
hello Ciclo is the other members,
at first I'm sorry for my english (translator) :?
I am looking for information on the possibility of being able to install the automatic lights with ch / lh and the top would beautomatic high beam in my polo 6r 2010what are the parts needed?here is a vcds scan today.
thank you for your feedback.
VIN: WVWZZZ6RZBY117435 Plaque d'immat.:
Kilometrage: 110400km Ordre réparation::
Type chassis: 6R (6N0)
Scanner: 01 02 03 08 09 10 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZBY117435 Kilometrage: 110400km
01-Moteur -- Etat: OK 0000
02-Boite auto -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
04-Angle de direction -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: OK 0000
10-Assistance stationnt -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
25-Anti-démarrage -- Etat: OK 0000
2E-Lect. multiméd. 3 -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
56-Radio -- Etat: OK 0000
Adresse 01: Moteur (J623-CAYB) Labels: 03L-906-023-CAY.clb
No. pièce Log: 03L 906 023 AH Mat: 03L 906 023 D
Pièce: R4 1.6l TDI H13 9980
Révision: --H13--- No. de série:
Codage: 00254016002400080000
No. Atelier: WSC 00788 648 00255
Jeu de données ASAM: EV_ECM16TDI02103L906023AH 003015
ROD: EV_ECM16TDI02103L906023AH_VW25.rod
VCID: 6CDC6C5C878BF641A33-8039
Aucun code défaut trouvé.
Tests passés: 0 0 0 0 1
Adresse 02: Boite auto Labels: 0AM-927-769.lbl
No. pièce Log: 0AM 300 050 P Mat: 0AM 927 769 D
Pièce: GSG DSG AG7 403 9030
Révision: 00040034 No. de série: CU501009135691
Codage: 0000020
No. Atelier: WSC 12288 002 1048576
VCID: 36688E3442477C91857-513C
Adresse 03: Freins ABS (J104) Labels: 6R0-907-37x-ESP82.clb
No. pièce Log: 6R0 907 379 AJ Mat: 6R0 907 379 AF
Pièce: ESP8.2i front H05 0001
Révision: --------
Codage: 210228E3416E00B9842914E582D600421300
VCID: 06083EF4B5272C11557-8053
Adresse 08: Climatronic (J255) Labels: 6R0-907-044.clb
No. pièce Log: 6R0 907 044 B Mat: 6R0 907 044 B
Pièce: Climatronic H08 0305
Révision: V0000000
VCID: 3260B2246D2F60B1A9F-8067
Adresse 09: Centrale Elec. (J519) Labels: FRM\6R0-937-08x-09.clb
No. pièce Log: 6R0 937 087 F Mat: 6R0 937 087
Pièce: BCM PQ25 H+4 H46 0221
Révision: BF046001 No. de série: 0345 267101965
Codage: 3EB02BBF08A10000013800003C2B0ED00080410F60040000200000000000
No. Atelier: WSC 124697 483 00190
VCID: 4084E8ECD383C2212FB-8015
Sous-système 1 - No. pièce: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Pièce: RLS 250910 05 54 0403
Codage: 0007FD
Sous-système 2 - No. pièce Log: 6R0 959 801 R Mat: 6R0 959 801 R Labels: 6R0-959-801.CLB
Pièce: J386__TSG_FT 006 0903
Codage: 18BC30
Sous-système 3 - No. pièce Log: 6R0 959 802 T Mat: 6R0 959 802 T Labels: 6R0-959-802.CLB
Pièce: J387__TSG_BT 006 0902
Codage: 08BC30
Sous-système 4 - No. pièce Log: 5K0 959 542 Mat: 5K0 959 542
Pièce: E221__MFL-TAS H05 0010
Codage: 020000
Sous-système 5 - No. pièce Log: 6R0 959 811 F Mat: 6R0 959 811 F
Pièce: J388__TSG_HL 006 0902
Codage: 08BC32
Sous-système 6 - No. pièce Log: 6R0 959 812 F Mat: 6R0 959 812 F
Pièce: J389__TSG_HR 006 0902
Codage: 08BC32
Adresse 10: Assistance stationnt (J446) Labels: 6R0-919-475.clb
No. pièce Log: 6R0 919 475 Mat: 6R0 919 475
Pièce: PARKHILFE 4K H07 0008
Révision: -------- No. de série: 71391025269410
Codage: 100101
Jeu de données ASAM: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2_VW25.rod
VCID: 7BFE5F00F2E561F93A9-802E
Adresse 15: Airbags (J234) Labels: 5K0-959-655.clb
No. pièce Log: 6R0 959 655 K Mat: 6R0 959 655 K
Pièce: VW10Airbag00K H09 0020
Révision: -------- No. de série: 003GX008C3YN
Codage: 00304B
Jeu de données ASAM: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A90CAC4EDBF0871F1F-801F
Capteur de collision du sac gonflable latéral; côté conducteur:
No. de série: 3572SRB40000CA30CA7C
Capteur de collision de sac gonflable latéral; côté passager:
No. de série: 3582SRB40000CA20612Z
Capteur de collision du sac gonflable latéral AR; côté cond.:
No. de série: 3515RRB405902CB8MGNJ
Capteur de collision du sac gonflable latéral AR; côté pass.:
No. de série: 3525RRB405T010DA59B
Adresse 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
No. pièce Log: 6R0 920 861 F Mat: 6R0 920 861 F
Pièce: KOMBI H04 0304
No. de série: 00000000000000
Codage: 140A00
Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 3874800C83538AE197B-806D
Codage: 140A00
Codage: 140A00
Adresse 19: Gateway CAN (J533) Labels: FRM\6N0-909-901.lbl
No. pièce Log: 6N0 909 901 Mat: 6R0 937 087
Pièce: GW-K-CAN TP20 0221
Codage: 002200
VCID: 70E4782CA3A312A19FB-8025
Adresse 25: Anti-démarrage (J334) Labels: 5K0-920-xxx-25.clb
No. pièce Log: 5K0 953 234 Mat: 5K0 953 234
Pièce: IMMO H04 0304
No. de série:
Codage: 000000
No. Atelier: WSC 00000 000 00000
Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AD06A448D7FE871D1F-803F
Adresse 2E: Lect. multiméd. 3 (J650) Labels: 5N0-035-342.lbl
No. pièce Log: 5N0 035 342 C Mat: 5N0 035 342 C
Pièce: SG EXT.PLAYER H13 0111
Révision: A1001003 No. de série: 7668262379
Codage: 010000
VCID: 2756537056ED15190E1-8072
Adresse 44: Direction assistée Labels: 6Q0-423-156.clb
No. pièce: 6R0 423 156 B
Pièce: LenkhilfeTRW V277
Codage: 11230
VCID: 2F66BB50EA1D4D59C61-807A
Adresse 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
No. pièce Log: 5M0 035 186 AA Mat: 5M0 035 186 AA
Pièce: Radio RCD310 016 0049
Révision: 01000000 No. de série: VWZ1Z2K8539277
Codage: 0100040002
VCID: 6BDE6F408A85F179AA9-803E
Re: polo 6r upgrade
Hi minib, welcome.
Please wait until Monday. Thanks for your patience.
Have a great weekend!
minib
Re: polo 6r upgrade
Post by minib »
hello yes no problem good weekend also
Re: polo 6r upgrade
Hi minib,
It's possible the Automatic lights, CH/LH, etc... in your 6R.
YOU need the following:
- BCM Max 7E0937090D, is the latest model. (my recommendation, contact firegrafik -forum user- to buy this BCM Max, he can help you in this)
- AUTO Light switch.
- Some wires.
- VCDS.
Similar process you must follow:
- https://drive.google.com/file/d/1cXw67i ... 9R6DO/view
- viewtopic.php?f=56&t=70853&p=529913#p529889
- viewtopic.php?f=56&t=70853&p=529913#p529529
HBA, Bi-xenon or LED headlights, etc ... (this info is in the forum)
The first thing is the BCM Max ADAPTATION to your 6R (installation guide above).
Recommendations:
- read the documentation (links) in English - very easy -.
- don't use the smartphone or translators (as long as possible).
minib
Re: polo 6r upgrade
Post by minib »
Hello ciclo
thanks for your return.
I will look at the links that you transmitted to me and contact firegrafik for the max bcm.
I come back to you when the purchase is done.
thank you
