My main beam on my 96 polo has failed. Fuses and bulbs are good. If I pull back on the stick, my high beam works. Side lights work although they don’t brighten when the ignition is switched on. Is this a relay fault? If so, which relay do I need to replace please as Haynes manual doesn’t mention where to find it...
Maybe a coincidence but I was driving through some really wet weather before I noticed the fault...
Please help
