Ecotek Valve
Ecotek Valve
Managed to fit an ecotek valve the weekend,
It looks schweet, makes the idle smoother and gives me some extra badda-bing when I press that go faster pedal.
Just gotta test if it makes it more fuel efficient.
it mildly rocks.
it mildly rocks.
Karl_CLCoupe
mmm. The noise is kinda flatulant, but is dulled to a small trouser rumble with the aid of the piper cross filter.madmatt wrote:they work ace but make a farty noise
my mate put one on his mondeo and removed the cat it help it pass mot with no cat co2 was lower than it should be
I'll run it this week and let you all know how much fuel I've saved.
Yeah, you learn to slowly hate the noise. I mean, at first, it isn't that bad, then after a while, it truley pisses you off.
I might consider getting a filter for it soon.
GroovyCarrot
- Sponsor
It has definatly put a bit more poke into the ol' 1272 and the go-go juice meter seems to be falling a little slower too. So I'm happy.GroovyCarrot wrote:If so that counts me outBut I'd be interested to know, there was a bit of a question mark over whether they could actually improve performance at all...
They do various conversions for people without brake servo lines, I've seen the one for the mini and a converter fits under the SU Carb with the ecotek attached to that, go look at their website.
http://www.ecotekplc.com/
and email them.
Karl_CLCoupe
Tahrey1043
but are you giving it a decent scientific style test?
otherwise it might all be in your head
never underestimate the power of subjectivity and a wallet lighter of sixty nicker to cloud your judgement....!
like if you were to do a motorway run somewhere 50 miles away and back at a constant speed without it, find out what your raw mpg is for that.... then measure it again next time you have to do that journey with the ecotek installed...
madmatt
- Moderator
i got one on my engine i aint got a servo just block the endGroovyCarrot wrote:So, does everyone who has one agree that they make a difference? Not that it matters terribly to me, I believe they're run off the brake servo? If so that counts me outBut I'd be interested to know, there was a bit of a question mark over whether they could actually improve performance at all...
look at the intake manifold and theres a pipe coming off it with a rivit in it to block it remove the manifold and drill out the rivit get a rubber pipe on to it fit the valve put another rubber pipe on the other end and block it up with a bolt or somthing solid saved me loads of fuel
Tahrey1043
Re: Hmm...
hmm. well.. maybe....retro wrote:click here
hey.. it's made me think i'm going faster and that's all i need...
