Does any one no of you can display short term mpg on active info display? Only seems to show long term???
Active info display
Re: Active info display
Press the OK button on the steering wheel to cycle between "this journey", "long term" and "since fill up".rm55mcc wrote: Tue Mar 10, 2020 7:37 am Does any one no of you can display short term mpg on active info display? Only seems to show long term???
POLO Clive
If it's the same as the previous Polo, press the OK button to toggle between long term, since refuel, and since start.
***EDIT*** Or more likely as monkeyhanger said as I was posting this
Sorted thanks [emoji1360]
Boxerboy
- Drives: Her Polo R. Or my car.
I've adjusted the alternative screen views 2 and 3, but every time I select parameters to display on the LH and RH dials it never saves my selection.
I can see that the default View 1 is preset, but expected View 2 and View 3 to be available for 2 drivers to show their choices.
Seems View 2 and View 3 are alse preset. But not to what I want.
Seems odd. Or am I missing a SAVE button somewhere.
Honest. I've read the manual and spent time poking the dashboard many times.
Dark_cze
- Drives: AW GTI with MT
I might remember it wrong since I setup my dial more than year ago.Boxerboy wrote: Thu Mar 12, 2020 8:30 pm I've adjusted the alternative screen views 2 and 3, but every time I select parameters to display on the LH and RH dials it never saves my selection.
There was auto/classic/view1/view2/view3 buttons. Auto and classic was preset and no way to change them and views1/2/3 whould be user presets. I changed view 1 to whatever I liked most and than pressed media or app connect button to go back to screen I ussualy use. I don't think there is save button.
Hold down on the view 1 ,2 or 3 when you set your Desired display setting it will turn yellow and save view 1 ,2 & 3
- OomStu_ZA
- Drives: 2019 VW Polo GTi
Ahhhh, thanks for that tip will try it once we out of lockdown.Teee wrote: Tue Mar 24, 2020 6:02 pm Hold down on the view 1 ,2 or 3 when you set your Desired display setting it will turn yellow and save view 1 ,2 & 3
Interestingly if you have no NAV from facotry there only 2 additional views for the AID, not 3, but makes sense to me all the same.
