1.8t deletes
jordanwatkinson1993
- Drives: Ibiza fr 1.8t
1.8t deletes
Anybody local to Huddersfield that knows how to do the deletes on the 1.8t engine I have a Ibiza fr same engine code as the polo gti BJX cars will pay well or any specialists locally anybody knows of?
Re: 1.8t deletes
Not sure, think someone in or near milnsbridge does ecu stuff, and theres a couple of guys in sowerby Bridge who are vag specialists, I'll see if can find out more details.
Bear with me as cant really pop down road to check at mo
jordanwatkinson1993
Re: 1.8t deletes
I know there’s vag automotive Halifax ways think there closed at the min the one in milnsbridge would be ideal I just want to know we’re to run the lines and put the resistors currently got a leak and fault codes it’s more so the plumbing side of it I need to do the codes don’t matter too much cheers mate very much appreciatedTurbocod wrote:Not sure, think someone in or near milnsbridge does ecu stuff, and theres a couple of guys in sowerby Bridge who are vag specialists, I'll see if can find out more details.
Re: 1.8t deletes
Did have a pop round to where guy I was thinking of has his workshop when I went to tesco as enroute for me, was shut up, his unit is/was by valley dubs near where vag automotive were before they moved to bigger place, think guy called Oliver. Not sure if Ash at vag automotive does it also.
There is a good couple videos on YouTube and threads on briskoda for the deletes and resistor fitting.
I have an S3 lump in the garage and have to do the deletes on it while I'm off, was going to put it in a mk3 golf or polo but my mate is desperate for one so I may have to help him out with it as I got too many things going on to get another project at present. Was getting ecu modded rather than resistors.
I'll try find the guy at huddersfield, milnsbridge area, its been a bit hectic pal.
Re: 1.8t deletes
Pro remaps and tuning, huddersfield, I contacted ages ago about immo defeat on my old car, not sure if can do it, give them a call mate.
jordanwatkinson1993
Re: 1.8t deletes
Yeah might give vag automotive a ring when or if there open I was gonna attempt it myself but if I’m honest I’m s**t [emoji23] watches all the videos and threads but my engine layout is different
jordanwatkinson1993
Re: 1.8t deletes
Are you local to Huddersfield then? What you drive?
jordanwatkinson1993
Re: 1.8t deletes
Nice one mate appreciate it anyway. My mates got a bam in a little lupo it’s nuts good motors next on list for me is a ko4 just few niggly bits to sort out first il check out that pro maps see what there sayingTurbocod wrote:Did have a pop round to where guy I was thinking of has his workshop when I went to tesco as enroute for me, was shut up, his unit is/was by valley dubs near where vag automotive were before they moved to bigger place, think guy called Oliver. Not sure if Ash at vag automotive does it also.
Re: 1.8t deletes
No worries, worth a try, may not be of use, but something to do in lockdown haha.
Not sure, but think I read the k04 fouls the abs, but i may be wrong, could be lhd does, I've read so much its starting to blur together now.
Re: 1.8t deletes
I'm in Sowerby Bridge, polo is only a 1.2 as it's my sons car for when he passes test, I'm driving it for now, and love it!
Loads of bits stored for future use, rear arb, coilovers, rear discs, cupra fronts, bluemotion kit etc.
Few bits done so far, drl indicators, auto headlights, new gti lamps, suspension set up, wings, upgrade on the stripy seats even. 15" golf alloys
Got it stupidly cheap as engine light was on, rewired it from lambda to inner wing, cured it, failed mot on headlight aim so not too bad.
Got an intergalactic mileage a4 estate too, mgf and old mini too.
jordanwatkinson1993
Re: 1.8t deletes
Iv not read anything about that il look into it il sacrifice my abs for 50 horses lol
jordanwatkinson1993
Re: 1.8t deletes
Yeah get that bam slammed in too nice when it works out like that good luck to your son on his test thanks for the reply mateTurbocod wrote:I'm in Sowerby Bridge, polo is only a 1.2 as it's my sons car for when he passes test, I'm driving it for now, and love it!
