ABS & STEERING LIGHT FAULT POLO 9N3 1.2
Polonerd09
Drives: Polo 1.2 2007
Post by Polonerd09 »
Hi Everyone
So i am going try and be as clear as possible in regards to my current issue .
I have a polo 9n3 2007 reg 1.2.
First issue :
The last couple of weeks the ABS light has been beeping on and off .
I did take the issue to the mechanic who mentioned that it might be the sensor at the rear of the car. [/list][/list]
second issue:
I was driving my car today and the steering light came on , my steering obviously went heavy and i couldn't steer the vehicle.
Turned the car on and off and the issue went away .
Can anyone give me their opinions on what the issue here might be taking the abs light and steering light into account.
I can assume this fix would be worth more than the actual value of the vehicle .
Re: ABS & STEERING LIGHT FAULT POLO 9N3 1.2
I'd suggest to bring the car to someone that can read the error codes via OBD.
Polonerd09
I have booked the car in for a diagnostic tomorrow to see what is going .
Will keep you updated and see what they say
Fair enough, thinking positively, you might just have two separate problems, first one could be a wheel sensor as suggested by your first mechanic and the second could be an undercharged battery or a dying battery.
Bug337
Drives: MK4 1.2 6V Petrol
Post by Bug337 »
Did you get anywhere with this? I’ve just joined and made a post with very similar symptoms!
