I know this is a Seat question but there are many resemblenses with Polo PQ so there might be some expertise here
A friend of mine with Seat recently upgrade his lowline cluster (1P0920810P SW0404) to a MFA+ cluster (5P0920850_SW0905).
The cluster is working well.
He already had a steering wheel with 12 buttons and most of them work, only the LEFT+RIGHT buttons on the right side (to switch to other menus) doesn't seem to work.
I've already checked some settings and codings with him but can't find any obvious issue.
Here is the steering wheel module with the buttons:
Teilenummer SW: 5K0 953 521 BN HW: 5K0 953 569 E
Bauteil: LENKS.MODUL 009 0136
Revision: FF010038 Seriennummer: 20100925200677
Codierung: 1082140002
Steuergerät für Multifunktionslenkrad:
Subsystem 1 - Teilenummer SW: 1P0 959 538 C HW: 1P0 959 538 C Labeldatei: DRV\3C8-959-537.CLB
Bauteil: E221__MFL-TAP H02 0102
Codierung: E20000
Does anyone here have an idea why only the LEFT+RIGHT buttons on the right side don't work?
If there is a mechanical failure, is there some way we can check that in some measure blocks?
Thank you in advance for any input!
Regards,
H2Deetoo
