BlueGT 2014 fan for radio - noisy.
Doesn't matter whether the head unit is switched off or on, there's a small fan that's making a rather annoying sound. It can only be heard when the engine is switched off. Would it be worth pulling the fuse for this fan, or would the head unit simply overheat?
Re: BlueGT 2014 fan for radio - noisy.
https://sndup.net/5tb9 here's the noise..
Dink
- Drives: 2015 GTI
the fan is built into the head unit so to pull fuse for the fan you'd lose the power to the radio.
