Polo 6N2 ABS module coding
mike18clark
Drives: 6N2 GTI
Post by mike18clark »
Hi all,
I have had a look online, and have used the search utility, and have not been able to find a definitive answer.
If I was to replace the ABS control module on my 6N2 GTI, would this require coding to the car? Currently have the dreaded 01276 code, and will be trying the repair documented on this website. Contemplating ordering a replacement unit, but don't want to be stuck with the same, or more errors!
Many thanks!
Re: Polo 6N2 ABS module coding
just transfer the old coding to the new module and you should be good to go
mike18clark
Drives: 6N2 GTI
What would be required to achieve that? Would VCDS-lite be sufficient enough?
mike18clark
Drives: 6N2 GTI
Probably, yes.
