I recently ordered a full set of 337 (GTi Anni.) pedals for my Polo, and IIRC I asked Martyn for RHD clutch and brake, LHD gas. Got them on Friday, so took the opportunity to fit them on Saturday.
Gas pedal went straight on with very little problems - you can lift the pedal up quite a bit from its rest position, which helps in getting the pedal on and making sure its secure
Original brake pedal came off after a little persuasion, but the 337 brake pedal is a different shape
So, the clutch pedal. This ones fine, but its unbelievably difficult to get on! Took a little while and some bruised fingertips to get the old one off, resorted to using an allen key to hook under the pedal and lever it off
Coincidentally, the part numbers I had delivered from Martyn are:
1M0 721 961A 337 Brake Pedal Rubber
1M0 721 275A 337 Clutch Pedal Rubber
Are these the RHD or LHD parts? They're supposed to be RHD!
Finally, does anyone have any suggestions on how to get the pedals on a bit more easily? I know they're gonna be a tight fit, so that they don't pop off mid-journey, but
It was suggested by a mate that a little silicone grease or fairy liquid or something might help get them on - when I figure out how to get them on and off a bit easier I'll be breaking out the araldite...
Help!!
