First post out here pretty desperate in all honesty
Need to see a tutorial or more importantly what socket is the hub nut and anything to note whilst doing
Cheers in advance
Wheel Bearing Replacement
Re: Wheel Bearing Replacement
36 mm thin wall 12 point socket
For bearings you will need a special tool or improvise.
Am I right in thinking crack that off get the drive shaft out the back and undo spline bolts and hit with hammer jobs a good un right?amer6R wrote: Sat Feb 20, 2021 8:15 pm 36 mm thin wall 12 point socket
If you dont have a breaker bar, or impact tool use your jack to unbolt the hub nut ( its torqued to around 220 Nm).
You will need 15 or 16 mm socket to remove the ball joint, after that use a punch, or thread the hub nut a few turn and tap it with a hammer to slide out the drive shaft.
Please note that sometimes the bolts from ball joint can spin, so use a wrench or locking pliers to hold it.
https://youtu.be/wmJPW39ufV4
https://youtu.be/SgUTi9T13og getho version
The hub nut 50 Nm + 45° degrees
spartacus68
- Drives: SOLD: 2015 1.4 TDI (90PS) Blue motion
Did the same job myself last year. Straight forward with the bearing puller tool. Can't be done otherwise.
viewtopic.php?f=56&t=75279
amer6R's first video is excellent. Avoid the second approach for obvious reasons.
Probably worth mentioning whether you're after the front or rear bearing
