I have a 2013 Polo which lost the "Outer" shell of the muffler (see the image of the offending bit of rust).
I am concerned that this may lead the muffler reaching higher temperatures and potentially causing issues with MPG, particularly since there is no heat shield between the fuel tank and the muffler.
Has anyone else had this outer shell come away from the muffler? Is it something that you would typically get fixed?
