Reverse camera retrofit
cvchris
Drives: AW
Post by cvchris »
Hello, I would like to install a reverse camera on my manual Polo AW (has the 8" display). I have seen some threads here with instructions and I would like to know if this https://www.aliexpress.com/item/3301073 ... 9.169870.0 is compatible with the vehicle, and if it is difficult for a person with no experience to install it. Also if there is a video tutorial that is available (could not find one), could you please attach it below? I have asked a local specialist for installing a camera and the cost was 750€ vs 150€ + install if the camera from the link is compatible.
Thanks!
Scotty_boy vw
Re: Reverse camera retrofit
Post by Scotty_boy vw »
Hi Chris
I have a friend who does retrofits who can fit this for you (as long as its the correct camera for your car)he can also fit & code other things that you might like!!!
If anyone wants anything get in touch with him on Whatsapp +447982622729
scott
cvchris
Drives: AW
Post by cvchris »
Hello Scott, thanks for the reply, I am actually in Greece so it will not be possible.
