Ready for my BCM upgrade...What's next?
Lucero79
Drives: Polo
Post by Lucero79 »
Hi all,
Thanks for your time with me, even though I don't have a Polo :D
BCM7E0937090C arrived, how can I post my autoscan here? Says invalid file extension. Could someone help me with the wiring I need to accomplish this fit (before I even get around to retrofitting anything). Does anyone still make the looms, or am I on my own.
ag69
Drives: 1.2TSi 77Kw 7DSG
Re: Ready for my BCM upgrade...What's next?
Post by ag69 »
Lucero79 wrote: Sun Jul 11, 2021 9:23 pm BCM7E0937090C arrived, how can I post my autoscan here? Says invalid file extension.
Click on "Post Reply"
And just copy and paste entire VCDS scan.
No need to upload it as attachment or so.
Lucero79
Drives: Polo
Post by Lucero79 »
Trying to post the autoscan,
Forbidden. Contains contacts. Message seems to be spam.
ag69
Post by ag69 »
Try to check this thread : viewtopic.php?f=56&t=65724
Scroll down till you find word/header "VCDS autoscan:"
And try to trim your scan and post.
remove the row with the web adress and you should be fine
Lucero79
Drives: Polo
Post by Lucero79 »
ag69 wrote: Tue Jul 13, 2021 5:11 am Try to check this thread : viewtopic.php?f=56&t=65724
Can't really see any difference
Lucero79
Drives: Polo
Post by Lucero79 »
iichel wrote: Tue Jul 13, 2021 7:38 am remove the row with the web adress and you should be fine
Tried that too. Interestingly your AutoScan in your polo thread has the web address though :?
Lucero79
Drives: Polo
Post by Lucero79 »
Looks like we have a winner!!
Saturday,10,July,2021,12:53:18:25072
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: VSSZZZ6JZDR082595   License Plate:
Mileage: 283780km-176332mi   Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR082595   Mileage: 283780km-176332miles
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
   Component: 1,6l R4 CR td H33 9651
   Revision: --H33---    Serial number:
   Coding: 00114016000500080000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_ECM16TDI02103L906023LE 003006
   ROD: EV_ECM16TDI02103L906023LK_SK25.rod
   VCID: 74B1DE9EDE3D30AB9BB-8020
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 100200DB007500B4082A00EB00D600000000
   Shop #: WSC 04941 000 00000
   VCID: 0059824E9A451C0B8F3-8054
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LGE000F0
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FCB6E0716AFBFDF-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 273972 km
                    Date: 2020.01.25
                    Time: 15:24:06
                    Voltage terminal 15: 12.20 V
                    Voltage terminal 30: 12.35 V
                    Terminal 15 status: On
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002541622-
   Shop #: WSC 06403 785 00200
   VCID: 2411EEDE22DDE02BCBB-8070
1 Fault Found:
00819 - High Pressure Sensor (G65)
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 69
                    Mileage: 283358 km
                    Time Indication: 0
                    Date: 2015.06.28
                    Time: 14:49:02
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 195121222
   Coding: 3C880BE88861250092200CF06E2B0CC8B00000FF608C0000200000000000
   Shop #: WSC 12345 123 61029
   VCID: 45D7535AC5A7F923FC5-8010
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3110
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3110
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No: 1K8 951 171 A
2 Faults Found:
00975 - Heated Rear Window (Z1)
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 283765 km
                    Time Indication: 0
                    Date: 2015.11.29
                    Time: 14:13:33
00446 - Function Limitation due to Under-Voltage
                    Fault Priority: 6
                    Fault Frequency: 27
                    Reset counter: 70
                    Time Indication: 0
   Component: VW10AirbagA0D H10 0020
   Revision: --------    Serial number: 003GX01AUF0M
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD6066EC39165B117-801E
   Serial number: 3495RRB400G4UHC4893L
   Serial number: 3505RRB400G4UHC4NHQG
   Part No SW: 6J0 920 904 L    HW: 6J0 920 904 L
   Component: KOMBI         H04 0508
   Coding: 410A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 34311E9E9EBD70AB5BB-8060
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 322300
   VCID: 70B9D28EAAA50C8B7F3-8024
   Component: IMMO          H04 0508
   Serial number:
   VCID: 6A8DC0E68CF9F65B317-803E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 10121
   Shop #: WSC 00049
   VCID: 3039128E63654C8B3F3-8064
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70B9D28EA6A50C8B7F3-8024
Address 56: Radio (J503)       Labels: None
   Part No SW: 6J2 035 153 H    HW: 6J2 035 153 H
   Component: Radio         H15 0302
   Revision: R0000000    Serial number: SEZAZ2M4945431
   Coding: 0505020002
   VCID: 2B0305E243032F530A1-807E
End----------(Elapsed Time: 01:23, VBatt start/end: 12.5V/12.4V)-----------
Lucero79
Drives: Polo
Post by Lucero79 »
Ok guys,
So what's possible? If I upgrade BCM, and money, time and parts are no problem, what, from this list, is likely to be dooable (using @iichel list of OEM retrofits)
OEM: Proper front windscreen with RLS (heated)
OEM: Auto Front light upgrade (ideally bi-xenon, but that would require auto levelling and headlight washers)
OEM: Folding/Heated mirrors
OEM: Power rear windows
OEM: Climate Control (over normal aircon)
OEM: Cruise Control
OEM: 6J facelift dashboard
OEM: infotainment upgrade (with BT, USB/UAX)
OEM: Heated front seats (but not essential as the seats are not leather)
Not sure what else that there could be that would make my life more enjoyable :D
Lucero79 wrote: Fri Jul 16, 2021 9:47 am Ok guys,
OEM: Proper front windscreen with RLS (heated) --> possible with 087K
OEM: Folding/Heated mirrors --> possible with 087K
OEM: Power rear windows --> possible with 087K
OEM: Climate Control (over normal aircon) --> possible with 087K
OEM: Cruise Control --> possible with 087K
OEM: 6J facelift dashboard --> possible with 087K
OEM: infotainment upgrade (with BT, USB/UAX) --> possible with 087K, for MIB PQ you perhaps need 7E0
OEM: Heated front seats (but not essential as the seats are not leather) --> possible with 087K
Lucero79
Drives: Polo
Post by Lucero79 »
ok, so not the BCM I got then :D
Lucero79
Drives: Polo
Post by Lucero79 »
Can anyone help? Have I got the wrong BCM for the upgrades planned?
It's not a wrong BCM. For the things I commented in bold, your current BCM is fine so the 090 is a bit overkill. For the others, an upgrade is needed.
Lucero79
Drives: Polo
Post by Lucero79 »
iichel wrote: Sat Jul 24, 2021 3:28 pm It's not a wrong BCM. For the things I commented in bold, your current BCM is fine so the 090 is a bit overkill. For the others, an upgrade is needed.
Oh wow, ok, I see what you are saying now. My current BCM is actually ok for most of the upgrades and wouldn't require any special wiring on my part. Is it likely then that the wiring looms in the car already contain most of the plugs / wiring needed for some of these upgrades?
No I expect none of the wiring to be there
