Hi I just bought 2015 polo Ive got problems with radio
Everything working connecting with bluetooth phone and music working well but when you turn to radio no sound
I tried everything no mute searching stations but no sound
Thanks for any help
2015 polo
Re: 2015 polo
Ken, while i do appreciate your enthousiasm, i tink one topic is enough. So i removed the other two.
Re: 2015 polo
Sorry about that I posted by mistake
Re: 2015 polo
Don't worry about it. It's okay
Re: 2015 polo
Is that the same response from radio on all options, ie DAB FM and AM, if so, why don't you try using a cheapish "windscreen mounted" aerial, just hang/drape it over the front passenger seat and don't even bother giving it power, just unplug the aerial lead that is currently plugged into the radio and plug in this cheap one to use as a test piece, so that you can move forward in your quest to sort this out - ie be able to work out if this is an aerial issue or a radio tuner issue.
