TORQUE SETTINGS
Martin H
Drives: Mk5 1.2 12 Valve
TORQUE SETTINGS
Post by Martin H »
Can anyone help me here?
I am looking for the torque settings for:
Big End bolts
Main Bearing bolts
Ladder Rack bolts
This is for my daughters 2014 Mk 5 1.2 12 valve engine.
I have tried and looked everywhere - the answer is usually there is no technical data as these parts are non replaceable and the lower half is not rebuilt - throw it away and replace!!!
Well - they sell the parts! Anyone got any knowledge on this?
Thanks for any help!!!
Re: TORQUE SETTINGS
you can find data on
 https://www.kolhosniki.ru/elsaonline
Martin H
Re: TORQUE SETTINGS
Post by Martin H »
Sadly that website is beyond me and my internet capabilities!
Re: TORQUE SETTINGS
Why, click on VW database before 2017.
Then fill out the data for your car, model, year, engine, transmission code, and the language of database.
Then after click on the green toolbox icon, and then find the thing you need.
Its prety interesting and simple if you give it a shot. It will also tell you how to dissasemble the parts etc.
Martin H
Re: TORQUE SETTINGS
Post by Martin H »
Thanks for your reply.
I actually did that and nothing happened. Do I have to sign up to the site?
Re: TORQUE SETTINGS
No you dont have to sign in.
Martin H
Re: TORQUE SETTINGS
Post by Martin H »
Many thanks - I’ve successfully got into the database.
Sadly I can’t find the information - I keep searching!
Thanks for your help
Re: TORQUE SETTINGS
I've been also looking, at it seems that they don't list the engine rebuild specs is ELSA. Maybe Autodata has this or Haynes ?
Martin H
Re: TORQUE SETTINGS
Post by Martin H »
Haynes certainly does not and as far as I know Autodata doesn’t either.
VW won’t give out the torques and all I get from them is that this procedure isn’t carried out! The engine lower half isn’t repaired - it is replaced!
