Polo 1.6 TDI injector issue
Kamster
Drives: Polo 6R 6R TDI
Post by Kamster »
Hey guys.
I've got an issue. So my polo 6R 1.6 tdi just come back from the garage with 1st and 2nd injector being replaced. There's a diesel leak around injector 2. He did say to me this is due to the rocker having a hair line crack. Is this correct?
I'm thinking it's the injector leak off pipe but he saying it's the rocker that needs replacing.
Btw he did fully replace the leak off pipes too.
Asking as I need to sell this once fixed. I've had nothing but injector issues with this car which I found out their notorious for. Over the 1.5 years I have replaced them 6 times.
Reason I'm asking is my brother who is abroad says it seems like the leak off pipe clip area.
Any help would be appreciated.
Re: Polo 1.6 TDI injector issue
You can wrap toilet paper or any kind of tissue paper around pipes and connectors. If they become wet you have the spot.
Like wrap them, start the car idle/ rev it and you will see if the paper becomes wet.
Replace the fuel filter
