2014 T5.1 Transporter BCM & Bi-Xenon
DanClarke
Drives: 64
Post by DanClarke »
Hi, New to the forum but I have been using a lot of great information from here, I have followed Ciclo’s guide to install factory Bi-Xenon headlights, I have upgraded the BCM to a 7H0 737 090D from a 7H0 737 087 and installed the necessary wiring. I have carried the coding from the BCM and gateway over to the new BCM also.
The issue i have is that with the new BCM I cannot lock the vehicle, I have programmed the keys and it registers the fob being pressed (indicators flash and red led on door pin light up) but it doesn’t lock, the inside door button doesn’t lock but will unlock, also doesn’t lock from the drivers door lock with key, if I plug my old BCM in it will lock fine,
I’m pretty stuck now and not sure what else to try? Help would be much appreciated, thanks, Dan.
DanClarke
Drives: 64
Re: 2014 T5.1 Transporter BCM & Bi-Xenon
Post by DanClarke »
Saturday,18,March,2023,11:09:06:06329
VCDS Version: 23.3.0.0 (x64)
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WV1ZZZ7HZEH085383 License Plate: B7
Mileage: 224220km-139323mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 56 61 77 0B
VIN: WV1ZZZ7HZEH085383 Mileage: 224220km-139323miles
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FK HW: 03L 907 309 M
Component: R4 2.0l TDI X45 9978
Revision: 26X45--- Serial number: 00000000000000 CVN: 878733E2
Coding: 01254012232400080000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20TDI01103L906019FK 004006
ROD: EV_ECM20TDI01103L906019FK_004.rod
VCID: 79F951BAF8C1EB5B84-802C
VINID: 9E606AAAA1D8A956002050C80C268C1547
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 P HW: 0BH 927 711 C
Component: DSG DQ500-7F H07 2550
Revision: 00H07V01 CVN: 8DBB5D58
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 428BF656D597688395-8016
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89AC0A9A24A59179A96110
Shop #: WSC 02736 790 49152
VCID: 3A7B8EB6B5472043CD-806E
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Count: 16384
Count: 1
Count: 8242
Count: 512
03391 - Coding Not Possible
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Count: 16384
Count: 1
Count: 8254
Count: 512
00474 - Control Module for Immobilizer
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Count: 16384
Count: 1
Count: 8211
Count: 512
Serial number: 03011404651330
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF342A6E1EFCC63B1-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02736 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 7CF748AEF7F3DE739F-8028
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0725
Revision: B9074001 Serial number: 0671 161142961
Coding: F8A030B80A212031002808712C2B9C550080668F60017841320000020000
Shop #: WSC 12345 123 61029
VCID: 2F6DAFE27E05F5EB6A-807A
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8652
Serial number: KU0KU007011440074337
Coding: 1000B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8652
Serial number: KU0KU010011440105625
Coding: 0000A0
Subsystem 3 - Part No SW: KU 0KU 010 01 HW: KU0 KU0 100 11
4401
Serial number: ÿKU0KU0100114401056
Coding: 353632
7 Faults Found:
03436 - Activation of Motor for Central Locking (Lock)
012 - Electrical Fault in Circuit - Intermittent
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 153
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 11:02:57
03301 - Response Closing Status of Drivers Door
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 11:02:58
03302 - Response Closing Status of Passenger's Door
Fault Priority: 2
Fault Frequency: 2
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 11:02:58
03303 - Response Closing Status of Rear Left Door
Fault Priority: 2
Fault Frequency: 2
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 11:02:58
03442 - Return Message Closing Status of Rear Lid
Fault Priority: 3
Fault Frequency: 2
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 11:04:03
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 11:02:53
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 11:02:53
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32961333800214
Coding: 108101
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A7B8EB6BD472043CD-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00MFVM2 Dataset Number: 7E0003v____ 0471
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 35619D8A9459CF3B20-8060
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 460800
VCID: 3169A99A6031E31B7C-8064
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0725
Revision: B9074001
Coding: 042300
VCID: 70EF6C9EA3BBAA1333-8024
1 Fault Found:
02811 - Control Module for Electronic Steering Column Lock (J764)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 10:45:54
Component: IMMO H04 0710
Serial number:
VCID: 6ADB7EF68D6750C37D-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 G HW: 3C0 035 279 G
Component: RNS315-EU H35 0263
Serial number: VWZAZ2L3870591
Coding: 040002010200000000019002
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 275D47C25EF5ADABA2-8072
Data carrier:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_0038 0038
6 Faults Found:
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Date: 2023.03.18
Time: 10:45:54
1048634 - Antenna 2 for radio
B111A 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Date: 2023.03.18
Time: 10:45:48
1048636 - Digital Radio Antenna
B1103 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Date: 2023.03.18
Time: 10:45:48
1048652 - Telephone Microphone
B1048 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Date: 2023.03.18
Time: 10:45:48
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [009] - General Memory Failure
Fault Priority: 4
Fault Frequency: 1
Mileage: 187197 km
Date: 2018.08.04
Time: 13:48:35
1048641 - Control Module Incorrectly Coded
U1014 00 [009] - -
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Date: 2023.03.18
Time: 10:45:49
Correction for sound system: OK
Traffic sign display: OK
CD-Changer: OK
Status of antenna 2 for radio: OK
Digital radio (DAB): OK
Antenna diagnostic: OK
Telephone baseplate diagnostic: OK
Speaker status: OK
Rearview camera: OK
Telephone Transceiver: Malfunction
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H74 0725
Coding: 030B1A5A
Shop #: WSC 73430 790 00104
VCID: 6BD57BF28A9D49CB06-803E
2 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 10:46:48
02252 - Generator
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 224226 km
Time Indication: 0
Date: 2017.08.08
Time: 10:46:48
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007665632810 Dataset Number: 7P6035730J 0001
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 397991BAB8412B5BC4-806C
End-------------------------(Elapsed Time: 02:56)--------------------------
Hm do you have a scan with the 087 BCM? Did you transfer coding and adaptations for bcm and can gateway?
DanClarke
Drives: 64
Post by DanClarke »
iichel wrote: Sat Mar 18, 2023 11:38 am Hm do you have a scan with the 087 BCM? Did you transfer coding and adaptations for bcm and can gateway?
I can post a scan of the 087 BCM but I have carried both the coding for the BCM and the gateway
Are you sure? Gateway is not happy with module 61 and 05 for example
DanClarke
Drives: 64
Post by DanClarke »
Yes I’m sure, I’m starting to think it’s the BCM itself at fault as it has locked a couple of times now when driving (auto lock) and button has worked a couple of times, you can also hear the BCM clicking when internal button is pressed but it doesn’t activate the locks most of the time
It looks like the BCM Max you have installed came from a vehicle (donor car) with Kessy.
GW:
1 Fault Found:
These BCMs can only be reprogrammed via online with VW servers.
Solution:
You need to find a New BCM Max or one that came from a donor car without Kessy.
I recommend the BCM Max 7E0 instead of the 7H0. The 7E0 are more up to date, they are better in terms of equipment compatibility.
I leave here some information for future searches.
-BCM replacement procedure:
:arrow: http://wiki.ross-tech.com/wiki/index.ph ... eplacement
Note: remember that for all keys/remotes you must enter the value 0 in channel 01. http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
-The way to get rid of address 61 from the GW installation list:
- Enable address 61 in Gateway installation list.
- Go to address 61 and code all Bytes to 00.
- Return to GW installation list and disable the address 61.
- Go to Autoscan and Click on Gateway installation list button.
- Click on Clear All DTCs.
The address 61 should no longer be present in the Autoscan.
DanClarke
Drives: 64
Post by DanClarke »
Thank you Ciclo for the information, I have managed to source and install the 7E0 module and now I can lock my vehicle!
Thanks again.
Great! Thank you for the report.👍
Please feel free to comment in this thread (your thread) any questions you have about your T5, here are 4 or 5 VW T5.1 users who can provide answers and solutions to them. ... apart from several mega experts with extensive experience in mechanical and other matters.
I also recommend:
https://www.t6forum.com/
https://forums.ross-tech.com/
