The girlfriends polo has been having an issue where the revs will drop by 200-300 rpm and then return to normal while idling in first gear.
I’m thinking a dodgey throttle position sensor might be the cause so I’m thinking of replacing the full throttle body and sensor all in one go.
Do I need to reprogram the car after replacing the throttle body? I know some cars will relearn themselves after a while .
I don’t want to go replacing the throttle body and end up needing a scan tool.
Any help appreciated
