I'm having some problems fitting a Sony AX3005DB Carplay head unit to a Polo 6R (2013); although my wiring harness has a canbus adapter, the switching on and off of the stereo doesn't happen as it should and I can't quite work out what is going wrong.
Turning the ignition on will power up the head unit, and then removing the key will power it down. However:
- If I repeat this in less than 10 seconds (on, off, wait 10 seconds, on) it still works
- If I wait more than 10 seconds, the head unit won't power up until I physically disconnect and reconnect the canbus adapter
