Help ! flat battery doors locked with the spinning door lock issue
mwain6969
Drives: 2010 1.2 TDI blue motion
Post by mwain6969 »
Hi All
My Daughters 2010 1.2 tdi had a flat battery yesterday , took it off and charged it over night when i went to put it back on this morning so helpful person has pushed the bonnet closed :x
the drivers door lock has the spinning lock issue ....... is there a way in other than a lock smith ?
TIA -
Re: Help ! flat battery doors locked with the spinning door lock issue
passenger door
Or remove the Wheel well liner and try to pull the cable
mwain6969
Post by mwain6969 »
Thanks is the passenger lock a blank cover with the lock underneath ? I didn't want to force it if it wasn't 👍
check if there is underneath. mine has locks on both sides
