Hello,
I've tried to research as much as possible and I cant find an answer I'm completely happy with.
I want to change the fog lights from that horrible yellow to some white ones, but I obviously don't want any error codes.
can somebody point me in the right direction with links to some bulbs which will be whiter than the current ones, and also preferably show some photos of their set up and the difference it makes.
White fog lights for AW Polo GTI
jakub_kisiel
- Drives: 2021 Polo GTI+
Harrihealey02
- Drives: 2018 SEL
Re: White fog lights for AW Polo GTI
https://autobeam.co.uk/collections/led- ... i-fog-unit
I used to have them in my AW polo or face lift and they were so much whiter and brighter than originals. No error codes plug and play. They come with a small box unit that goes between the plug and the bulb which I think stops the error code but is plug and play takes 10 second to install.
jakub_kisiel
Ok thanks, I will check it out.Harrihealey02 wrote: Tue Jul 11, 2023 7:30 pm https://autobeam.co.uk/collections/led- ... i-fog-unit
Mike222
- Drives: Tiago R Line (Black edition)
Facelift GTI with iq lighting . What’s the legal position about front foglamps ( if that’s what they are ! ) being on at the same time as the headlights ? I’m sure that it is legal to drive with “foglamps on unless visibility is reduced ( highway code rule 226 ) ??
