flashing doesn't quite do the same job. is cheaper for a reason, it's not as good.
I used it on my last car and will never use it again.
It's not as sticky as dynamat and dynamat extreme. and you need to use a lot more of it to get the same results.
I would never use it in my doors, when my door panels got hot from the sun, the flashing began to peel off, not good if it gets stuck on your windows!!!!!
On my polo I have used some sound deadening from the
www.bodyshopwarehouse.co.uk look for the patterned stuff.
much better than flashing but still cheaper than dynamat.
Car audio direct are doing a bulk pack of dynamat extreme on offer at the mo, check it out as its good value for money.
