All other Polos and Golfs have pumps with arrows pointing towards the way it goes it to match with the outside. Not this pump. All I see is the letter 'T' and 'R' on the pump with no outside reference to match it to.
I replaced the pump with a used one after the vehicle cut off despite having a quarter tank remaining.
I tested the replacement out of the tank and it works. Put it in and showed empty on first install. Tried again, showed the correct level. Installed, started the car. Just started to move off and the tank flew down to empty.
Cannot get it back working again. Please if anyone can take a photo of their fuel pump so I can see which way the arrows should face? If you lift the rear seat and twist off the connector seal plate its visible. Its the blue pump model. Part number 6R0919051N.
Fuel Sender/Pump 1.2 TSI 2015, which way do the arrows face?
Re: Fuel Sender/Pump 1.2 TSI 2015, which way do the arrows face?
– Note installation position of fuel delivery unit flange: mark on
flange -2- must align with mark on fuel tank -1-.
