Hello all,
Recently when I tried to replace key fob shell on my Polo 9n3 1.4 TDI I've broken original transponder chip (everything else in key is working). I want to replace broken transponder chip in key with blank one and adapt it with VCDS. I've retrieved SKC from dashboard (IMMO PIN). Also I have another functional spare key.
Can someone tell me , how to adapt new blank transponder in the first key with the second working key in VCDS?
Polo 9N3 transponder chip adaptation
davlulham
- Drives: 9n3 1.4 S
Re: Polo 9N3 transponder chip adaptation
Did you figure this one out in the end? I have exactly the same issue...
