Aftermarket reversing camera
Posted: Fri Jul 26, 2024 10:43 am
by lebjos
Hi all,
I am considering having a reversing camera retrofitted to my 2016 Polo 6C. I've found two companies that can do it. Both will install the camera above the numberplate, but the camera software technology looks different (the latter looks to offer more options but does not display the parking sensors). Has anyone got experience with either of these two companies?
https://www.autologics.co.uk/vw-polo-re ... %20fullest!
https://www.vw-retrofit.co.uk/product/p ... -retrofit/
Re: Aftermarket reversing camera
Posted: Fri Jul 26, 2024 10:45 am
by Maarten
Why not choose the emblem camera?
Better overview and no problems with dirt and water collecting on the lens
Your first link is installation in the emblem
Posted: Fri Jul 26, 2024 10:50 am
by lebjos
Maarten wrote: Fri Jul 26, 2024 10:45 am
That picture is just an example, the 6C doesn't support the badge-mounted camera unfortunately.
Posted: Fri Jul 26, 2024 11:05 am
by Maarten
3 or 4 years ago I mounted a emblem camera on a 6C (MY2016)
So it is possible
Posted: Fri Jul 26, 2024 11:09 am
by lebjos
Maarten wrote: Fri Jul 26, 2024 11:05 am
So it is possible
Very nice - unfortunately these two are my only options (both number plate mounted)
by ciclo
In this forum the 6C does support the camera in the emblem since someone very crazy decided to make an adapter with autocad.
Posted: Fri Jul 26, 2024 11:17 am
by lebjos
ciclo wrote: Fri Jul 26, 2024 11:09 am
Sure. Does anyone have any experience with the two links I posted?
Posted: Fri Jul 26, 2024 2:30 pm
by 2226
Those are most likel the exact same thing.
As an extra question, what is needed to use the highline version they're advertising compared to lowline?
Is there extra control module for the highline emblem camera or is that usually contained in the camera itself with connection to canbus wiring?
Lowline is usually just video feed into media box and reverse signal tapped off reverse light wiring.
Highline is canbus triggered.
Posted: Fri Jul 26, 2024 2:50 pm
by peter_dk25
Posted: Fri Jul 26, 2024 5:17 pm
by 2226
That's a low line unit. Reverse signal taken off the reverse light wiring.
Highline is connected to canbus, operates on reverse message on canbus, sends latch open signal to canbus.
Adapters and cameras can be found on Aliexpress. They are actual VW parts from the Chinese VW market.
Just can't tell if there's a separate unit for the canbus comms or whether it is built in.
Posted: Fri Jul 26, 2024 8:51 pm
by ciclo
In theory, the RVC High 5Q0 980 556 B (KA2) could be installed in a POLO 6C by connecting it to the CAN Bus of the infotainment system.
Additional Information
viewtopic.php?p=581351#p581351
Posted: Fri Jul 26, 2024 9:16 pm
by 2226
ciclo wrote: Fri Jul 26, 2024 8:51 pm
Awesome info. Thank you!
Posted: Sat Jul 27, 2024 12:53 am
by Tinman
Posted: Sat Jul 27, 2024 2:41 am
by ciclo
Thank you for such valuable information.
Security Access:
801129
Try it.
It could also be 20103.
The RVC High 5Q0980556B can also be installed on the bumper.
BTW,
No copyright.
