anyone got any ideas?
engine cutting out.
engine cutting out.
at night when i dip the clutch after ive been accelerating the engine sometimes dies or ticks over at 500rpm or less, i disconnected the cold air feed and even connected a warm one
lord_sharpy
stalling
mine occasionally does it when the petrol needle is between the red and white at the bottom of the guage. i thought it might be due to the petrol sloshing around the tank and allowing air bubbles to go through the injector system. ive got a new petrol filter to go on and i also put some injector cleaner through last time which seemed to work.
heartagram
Mine did that.
I used to get up in the morning, drive to the end of my road, dip the clutch to stop, and the engine would just die, or as you say, tick over very slowly and just manage not to stall (battery light would flicker though.)
It was a right ball ache, but I solved it by replacing the blue temp sender.
GroovyCarrot
- Sponsor
Tahrey1043
hmmmmm I quite like the cold air getting into the engine, more air and all that. I just upped the idle point a little and it runs lovely. Might sort it out properly one day... Go look at the temp senders and all that.metz wrote:Just found out what my problem was..the cold air pipe!
took it off as the weather is cold and reset the ECU, now the cars runs fine.
hardhitter
- Moderator
Tahrey1043
Gareth_GT_Hatch
hardhitter
- Moderator
