track day
david burton
david burton
hardhitter
- Moderator
david burton
polog40racer
Ive got a G40 track day car.
Yes its worth it, yes it is lots of fun, its usually the fastest thing out on track too!
Mind you we have prepped mine alot. Its fully seam and stitch welded, stripped out, full rollcage, seat, harnesses etc, KW coilovers, bracing, cornerweighted, mad bonkers engine, etc etc etc. Still plenty to do, but im going hardcore on it, i.e wishbone setup, LSD, ET20 wheels for wider track and more rubber down. Keep it on 13" wheels too!
For a fun track day car, get some koni/eibach suspension, decent tyres, raicam brake pads and racing brake fluid (motul RBF600 highly recc.) and a 4 point harness, helmet, chip and pulley it or something for 150bhp. Easy as! And Cheap!
polog40racer
My brakes are awesome mate! Try them to believe them!!!!
Current setup is 239mm vented standard Vag Discs, Raicam brake pads (available from Pitstop Developments), braided hoses, Motul RBF600F brake fluid. Its the pads and fluid that does the business.
Another method is to ditch the servo and convert to tilton twin master cylinders. These are also an awesome setup. All proven aswell!!!!!!
Ive decided to go to 14*7 ET20 wheels due to tyre availablility on a 13" rim, but even if I had a 13" rim. Yes, you can fit a hi-spec 260mm 114-4 caliper 4pot setup underneath 13's, but not the G40 BBS wheels though since they have a tapered inside. Compomotive CXR's are best to use!
Im going for 4pots but currently undecided on disc size as yet, waiting for the wheels to arrive first before measurements can be done.
Trust me my son, I know what im on about!!!!! My G is very hardcore!
