HELP!!!!!!!!!!!!!!!!
Discuss In Car Entertainment
robert.cheetham
Post by robert.cheetham »
I am having serious trobles wiring up my sub and amp. I have the cables running thorugh car so all i have to do now is connect them. :?
I have an splx sub and amp. Can anyone tell me where each wire goes. Also where is the best place to earth it? i have a mk3
neilw
Post by neilw »
Plug in the RCA cables from your head unit - these are the ones that carry the music signal back.
Plug in your remote wire - this come from the head unit, and is there so the amp only turns on when your head unit is on, savin your battery
Connect your sub to the speaker outputs on the amp
connect the earth cable - look behind your rear clusters for somewhere to earth it, im not familure with mk3s but normally find teres a bolt around there you can hook up too.
connect the power cable
should work....
