OK. It's fitted in fine, but Now I've come to put the blank bit underneath, the storage space thing. Before I had the CD changer and Gamma unit.
But it doesn't fit properly.
Do I need to take the spacer out in the middle??
If I do then I wish I did that before putting it in.
James.
EDIT:
Actually no panico, I did need to take the spacer out.
Now heres a pic!
Will have to wait until dark to get a better shot of the illumination. It's basiclly the same as the rest of the dash but slightly lighter, you can however adjust the contrast to make it look "right"
The big advantage over CD Changer is you can use mp3 CD's and put around 14 CD's worth on there.
